configure bgp neighbor source-interface
configure bgp neighbor [remoteaddr | all] source-interface [any | ipaddress ipAddr]
Description
Changes the BGP source interface for TCP connections.
Syntax Description
remoteaddr Specifies the IPv4 or IPv6 address of a BGP neighbor.
all Specifies all IPv4 and IPv6 neighbors.
any Specifies any source interface.
ipAddr Specifies the IP address of a source interface.
Default
Any.
Usage Guidelines
The source interface IP address must be a valid IP address of any VLAN configured on the switch.
This command applies to the current VR or VRF context.
The following command changes the BGP source interface to 10.43.55.10:
configure bgp neighbor 192.168.1.5 source-interface ipaddress 10.43.55.10
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
